Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
1951 C wont crank
michael bailey
12-17-2013 10:11:26
97.95.192.128
Was out plowing today and I stalled it. Tried to re crank and It made a bang and now no starter action at all. Trying to narrow it down, so I jumped across the solenoid and it click very lightly but no turn. Any ideas
[Reply]   [No Email]
FBH44
12-18-2013 03:41:46
64.85.214.206
 Re: 1951 C wont crank in reply to michael bailey, 12-17-2013 10:11:26
Had similar situation, sorta similar, turned out the alternator hadnot been charging, the battery had gone dead.
[Reply]  [No Email]
Dennis K (WA)
12-17-2013 18:40:11
24.21.78.195
Will the engine crank by hand??
Have in neutral for sure.
Dennis
[Reply]  [No Email]
michael bailey
12-17-2013 14:02:08
97.95.192.128
Took the starter off and the bendix was stuck forward. got it free and reinstalled. Still nothing. I got a small click out of the solenoid but nothing else. Tried jumping straight to starter and nothing. just an arc and no spin. I am think the brushes might be gone
[Reply]  [No Email]
Janicholson
12-17-2013 18:35:46
74.60.94.18
 Re: 1951 C wont crank in reply to michael bailey, 12-17-2013 14:02:08
Or an internal short to ground. Take it apart! Jim
[Reply]  [No Email]
old
12-17-2013 11:54:33
209.86.226.34
Made a bang that maybe a few things. A weak battery can cause that and that bang was the starter bendex jamming in the ring gear. So now you may have 2 problems. #1 low battery that needs charged and a locked up starter. I would loosen the starter bolts and or take them out and make sure the starter is not broken or locked up and also check the battery. If both are good check all battery cable connections
[Reply]  [No Email]
mkirsch
12-17-2013 11:31:59
65.199.189.6
Starter is real easy to remove. Less than 5 minutes. Unhook the ground cable to the battery. Disconnect the battery cable from the starter. Undo two bolts. Slide starter out.
When you get the starter out it may be VERY obvious what the problem is.
Once you've done that, try to crank the engine by hand just to see if it is free. If the engine won't crank over by hand (transmission in NEUTRAL) you got big problems. Time to drop the oil pan and pull the valve cover, and possibly the head.
[Reply]  [No Email]
El Toro
12-17-2013 11:29:44
96.244.7.206
Do as Jim suggested and check your battery using a hydrometer and record the readings and if one cell reads 1.100 you have dead cell. Hal
[Reply]  [No Email]
Brian Schmidt
12-17-2013 11:03:22
166.147.88.19
Put it in 4th gear shut off and rock it back and forth by hand. Sometimes the bendix will wedge in against the ring gear. If this doesn't help, pull the starter off and inspect. If all looks good, reinstall and try again.
[Reply]  [No Email]
gene bender
12-17-2013 10:58:45
207.177.56.213
Solenoid you must have changed someting as they didnt have one. Your Bendix mite just have broke pull the starter and check.
[Reply]  [No Email]
Michael bailey
12-17-2013 13:59:30
97.95.192.128
 Re: 1951 C wont crank in reply to gene bender, 12-17-2013 10:58:45
yes it has been converted to 12 volts
[Reply]  [No Email]
Janicholson
12-17-2013 10:30:05
199.17.6.25
battery gone bad. check the lights, or use a volt meter to assess. Jim
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
