Zachary Hoyt
My 300 does not start nicely when the temp is below 20 or so. It
starts right up, runs for about ten seconds and then dies and
that is it. I had a small hang-off-to-the-side coolant heater that
came with it that I hooked up last winter but it did not help. The
hose going out of the heater would be warm but not hot and the
temp gauge never showed anything. I am thinking about getting
a heater that goes in the lower radiator hose and am wondering
how many watts I need to really be able to warm up the engine
enough to matter and if there is a brand to look for or to avoid. I
occasionally have lows down to -30 F but mostly this would only
be down to -10 or higher. The tractor is inside an unheated
building right next to a plug. Any advice will be very much
appreciated.
Zach
appreciated.
Zach
