Yesterday's Tractor Co. Fast, Friendly Parts Service
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
1586 throttle lever stuck
Dave H (MI)
12-16-2013 17:05:45
108.100.43.113
Been pretty cold here and it warmed up a tad so I thought I best run the 1586. Turns over just fine but I cannot move the speed control from the "off" position to where it will start. Assuming that the linkage runs to someplace where some water has frozen....but I know little about diesels, not sure where that linkage runs outside the cab, and it is frickin cold out there.
So I thought I would ask. :)
Is there a likely spot where it has frozen up with ice? Thank you and Merry Christmas!
[Reply]   [No Email]
Dave H (MI)
12-17-2013 08:37:56
173.149.30.128
 Re: 1586 throttle lever stuck in reply to Dave H (MI), 12-16-2013 17:05:45
appreciate the info! It was not hard to find where it is or to see how it could happen. I think a brooder light at a discrete distance will help that a lot. Thanks again!
[Reply]  [No Email]
Hugh McKinney
12-16-2013 19:55:22
75.104.206.23
The easiest way to find it is to start at the injection pump, on the left side, just above the frame rail, and work your way backwards til you come to the lowest point, which is likely the location of the ice. Get you a good propane torch if you don't have electricity where it is, but take it slow! Good luck, Hugh
[Reply]  [No Email]
Janicholson
12-16-2013 19:20:44
74.60.94.18
They are correct. Taking it off and warming it to above freezing will cure it temporarily. Putting a cable lubing adapter on the end (motorcycle shops) and forcing lube the full length will make it new. Jim
[Reply]  [No Email]
Caseyc
12-16-2013 17:11:46
174.225.229.209
I would've beat you if I was at my PC. I type slow on my phone...
[Reply]  [No Email]
Caseyc
12-16-2013 17:10:12
174.225.229.209
86 series use a cable. Water can get in it and freeze. Either throw some heat on it or replace it. It's not to bad. Don plenty of them in sub zero temps. Not fun getting under the dash but not as bad as the T/A cable...
Casey in SD
[Reply]  [No Email]
Moline_guy
12-16-2013 17:09:22
216.249.226.165
Your throttle cable must have some moisture in it. Mind did the same thing, I just put a new one on it, not much to put one in. You could try to spray some wd40 into the ends. If you have a heater of some such to blow hot air onto the cable, it might free up, the lowest point is betwwen the cab and injection pump.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
