Cub Air cleaner
Just wondering, most cubs I see have the domes cap and screen on the air intake, and I was wondering if International harvester offered a air cleaner with the special ball jar like was on a lot of the larger letter series tractor. I believe they have a 1 3/8 inch OD on the riser pipe. I have also heard of aftermarket ones, but have not looked for any yet.
They were never factory installed. There were units available at the dealers that would fit. Well, they fit the early Cubs pretty well but the later Cubs had a real short intake pipe. I'm not sure how well they would fit a short pipe.
Steiner Tractor has them, they are up to around 100.00 bucks
1 800 234 3280. They look and fit pretty good, I have bought two of them. The air stacks on the newer cubs are lower than the early models, but you can swap air filter housing if you have a newer model cub.
JG
