TractorLinks.com
Show Parts for Model:
Farmall M 3 Point to Drawbar
Tuna_3380
12-11-2013 17:34:51
Hey Guys
Just bought a partially restored 47 M. It came with a newer 3 point hitch, but im looking to sell that and bring back to stock with a swinging drawbar. Just getting opinions on drawbars and where to find good solid used components in general. This is my first Farmall tractor restoration. Look forward to hearing from you all.
Ellis Kinney
12-12-2013 18:21:34
 Re: Farmall M 3 Point to Drawbar in reply to Tuna_3380, 12-11-2013 17:34:51
The Saginaw 3 point hitch is made to work with the original drawbar. My Worksaver 3 point hitch comes with a bracket that holds the swinging drawbar up. I sure wouldn't remove the hitch. Ellis
hadley
12-12-2013 08:00:19
Where are you located and how much would you want for the 3 point if you are going to sell it?
D Slater
12-12-2013 06:06:43
First picture would be what came on a 47 model. Swing drawbar pivot and pin is pictured like the one only used on very early tractors though. Pivot casting had to be unbolted from the transmission to remove the swing pin on those. Later ones had the little plate show in the picture that could be removed to let pin out the bottom of the casting. Also real early tractors used longer angle brackets and support rods. Probably in 1940 and earlier tractors going on my memory. Picture with the roller is the last type attachment IH sold as replacement parts for a M tractor. Swinging drawbar anchor was changed. Both the U and swing drawbar was made thicker. Roller used on the swing drawbar. Rollers also had a change along the way with the mounting hole location for the roller. Different hardness of the drawbar metals and fine threads sometimes were used on the angle bracket attaching eye bolts were changes since 1947. U and swing drawbars in real good condition are kind of hard to find.
mkirsch
12-12-2013 05:10:16
Luckily, you are working on the second most common IH tractor of all time. Find your local tractor salvage yard. They are certain to have an M or three on the lot, and you should be able to get any part you need.
rankrank1
12-11-2013 19:12:48
Well, the better designed aftermarket 3 point hitches allow the factory U shaped drawbar as well as the swinging drawbar to be retained.
Tractor is a whole lot more useful with the 3-point on it. I would recommend keeping that 3 point kit instead of selling it if I were you. I have added a 3 point kit to my Farmall h and am in the process off adding a 3 point kit to my Farmall M. Both will retain factory drawbars although I am having to do some modifications on the M kit as it was not originally designed to keep the factory drawbar like the one on my h was. Few simple mods and it will be good to go.
Tractor junk yards best place to acquire the missing parts you need.
Janicholson
12-11-2013 17:48:36
A drawbar The bent long steel going under the trans to a pivot, should come from an M, SM, SMTA, or from a 400 or 450 with no fast hitch. The Bend inthe bar, and pin hole size are different than those on an H/SH. The "U" shaped part is heavier in thickness than the nearly identical "U" on an H series (including SH). The Roller was optional and (I think) desirable. Many salvage yards have them. Jim
The Dukester
12-11-2013 20:03:57
 Re: Farmall M 3 Point to Drawbar in reply to Janicholson, 12-11-2013 17:48:36
Jim, I might be wrong, but I believe the swinging drawbars on M's were not as thick as the ones on the Supers and number models and they used a strap over the loop drawbar. The roller type swinging drawbar was standard on the Supers and later number models, not an option. A lot of guys put the rollers on their M's when they became available. True, the H had a lighter loop and swinging drawbar with a strap, but I'm not sure what the Super H's and number models had except that as I remember they had the roller retainer too. I worked some at a dealership when the Supers and then number models came out...but that was a while back and I admit my memory isn't what it used to be.
