TractorLinks.com
Show Parts for Model:
Re: Super A cylinder head
gene bender
12-11-2013 10:23:33
Check by putting some modeling clay on top of the domed piston then set the head on and turn engine over as early heads wouldnt allow some hi-dome pistons to clear. What is the cast code on the head. I dont have the parts book rite now. It also depends on the dome as RED POWER ones have a tall dome.
GRAPE-DRANK
12-12-2013 10:59:19
 Re: Super A cylinder head in reply to gene bender, 12-11-2013 10:23:33
I used red power domed pistons Gene. My head and block were both milled. After putting the sleeves in a micrometer showed that the sleeves were just a tiny fraction out of spec. I can't remember but it was a teeny tiny number out of spec according to the service manual. Deck a d head were shaved and I has no clearance issues. I don't know the exact number, but I took a pic of the high spot when we measured. I'll try to find it.
To the OP. All the heads RTR mentioned is correct, but I will add in the rare chance you come across a 240 that will work too. I can't remember how many different valve train kits there are for the 113/123 c.i. Engine, but to piggyback on what Gene said, there is more than 1 kit out there.
I used a 130 block and a Super A head. 3 angle valve job, domed pistons and a shaved block and head. I might have only 20 horsepower, but man does it have good compression. With the exception of the freeze crack forming on the block these are really good engines.
GRAPE-DRANK
12-12-2013 11:03:12
 Re: Super A cylinder head in reply to GRAPE-DRANK, 12-12-2013 10:59:19
BTW Ed, NC has a strong network of International Harvester fans. I go to the IHC 37 plow days when I can. There are salvage yards all over NC. I know where a bunch of heads are on the eastern side of NC.
