TractorLinks.com
Show Parts for Model:
Re: Woods Mower blade spindle
Russ from MN
12-11-2013 07:38:26
I have taken them apart, and mine weren't that tight, yours must be rusted pretty bad. Be very careful how you support the housing, use a full circle under the housing, not the flange, they break quite easily. Don't ask how I know this, but I got pretty good at brazing! Because it will be hard to get the pin hole lined up again, and the bearing clearance may not be correct, they recommend replacing the whole unit. A dumb system, but it sells parts. How much harder would it of been to have a nut and lock washer like a wheel bearing spindle. The bottom line is if you grease it occasionally and keep it indoors they will last forever.
