TractorLinks.com
Show Parts for Model:
Re: Farmall H Parts
FBH44
12-11-2013 02:38:19
easy way to put in those seals is
Bolster - have to pull them in with the open-end facing the grease. Either borrow the old-style seal puller from your CaseIH dealer, or rig up one out of all-thread / sockets / washers / nuts/ duct tape / etc. and pull them into place Took me three each; one to ruin, one to bend, thirdtime charm. Brakes - push them in gently with a PVC pipe or PVC fitting of the exact diameter. Best of luck. Christmas parade starts in three days, better hurry.
S2710
12-11-2013 06:00:17
 Re: Farmall H Parts in reply to FBH44, 12-11-2013 02:38:19
When you put the seals in the bolster you get two pieces of pipe that will fit over the bolster shaft and the outside of the pipe is the same size as the seal and then you slide the two pipes on the bolster shaft and then place the seal on top and raise the shaft up in place and put the nut on to hold it. Then you slide the top pipe up to push the seal up to where it is suppose to be and use the bottom pipe as a slide hammer. When you do it that way the seal is square and goes right in with no bending.
Bob
