TractorLinks.com
Show Parts for Model:
Re: '42 H Carb Help
old
12-09-2013 15:06:24
If it ran when you parked it the timing will not have jumped out of place. Timing is almost never a problem unless some one pulled the distributor off the tractor. One thing you should check is the air cleaner since you said it sat a long time the air cleaner maybe clogged up
farmallhal
12-09-2013 16:08:45
 Re: '42 H Carb Help in reply to old, 12-09-2013 15:06:24
I totally agree with old and David G that unless someone has had the distributor out after it was parked timing is probably not involved in your problem. In fact, I have never had to adjust the timing on my Farmalls once they were set up correctly to start with, Hal.
old
12-09-2013 18:24:00
 Re: '42 H Carb Help in reply to farmallhal, 12-09-2013 16:08:45
So how is this global warming doing down your way?? I have all of maybe 1.5 inches of snow here
farmallhal
12-09-2013 18:53:54
 Re: '42 H Carb Help in reply to old, 12-09-2013 18:24:00
Email sent but you must be living good as the snow found us for a good 6 inches. Looking forward to some global warming for sure, Hal.
David G
12-09-2013 15:48:13
I agree with Old, if it ran before do not mess with timing.
