What kinda fitting is this?
I ordered a new sediment bulb for my H. This is what I got. a conventional compression ferrel won't work with it. Is it a one time use fitting? Does it compress onto the steel line?
Thanks for the help,
Stumpy
The ferrule is already on the fitting. Just assemble as usual and tighten it down. The ferrule will break loose from the fitting and compress on the fuel line.
