Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Super C wiring
Janicholson
11-28-2013 20:37:50
To set it up negative ground, put the battery in with negative ground. Do not stert it. Use a piece of #10 wire (solid wire copper with vinyl insulation is good) to jump across the regulator from Bat to Arm terminals. You will need to reverse the wiring on the amp meter as the meter will read backwards if you do not. Jim
