Yesterday's Tractor Co. Fast, Friendly Parts Service
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Super C wiring
Don Hanvey
11-28-2013 20:07:39
98.89.97.191
Would it be better to stay with a positive ground or could I change it to a negative ground?
Is there a wiring diagram available on the net?
[Reply]   [No Email]
gene bender
11-30-2013 02:45:16
207.177.56.213
 Re: Super C wiring in reply to Don Hanvey, 11-28-2013 20:07:39
Why change ground your reg wont like it and then you will need to find a 6v neg grnd regulator to bolt where the present one is. Just leave it pos gnd.
[Reply]  [No Email]
teddy52food
11-29-2013 06:50:27
184.94.175.179
Mine has been running fine on 6 volt positive ground since 1951. Why change it?
[Reply]  [No Email]
Don Hanvey
11-29-2013 19:32:36
98.89.108.106
 Re: Super C wiring in reply to teddy52food, 11-29-2013 06:50:27
I would like to leave it original. R u still using the generator. If the battery is dead , can u jump it off with a 12 volt battery?
[Reply]  [No Email]
teddy52food
11-30-2013 06:44:31
184.94.175.179
 Re: Super C wiring in reply to Don Hanvey, 11-29-2013 19:32:36
I am still using the generator. You can jump it if you know what you are doing. Best to charge the battery & find out why it is dead.
[Reply]  [No Email]
Janicholson
11-28-2013 20:32:23
74.60.94.18
It does not matter which unless you put in an alternator. in which case negative ground is easier and cheaper.
[Reply]  [No Email]
Janicholson
11-28-2013 20:37:50
74.60.94.18
 Re: Super C wiring in reply to Janicholson, 11-28-2013 20:32:23
To set it up negative ground, put the battery in with negative ground. Do not stert it. Use a piece of #10 wire (solid wire copper with vinyl insulation is good) to jump across the regulator from Bat to Arm terminals. You will need to reverse the wiring on the amp meter as the meter will read backwards if you do not. Jim
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
