Farmall h wide front
Not without dramatic effort. The bolt pattern on the bolster is different, the frame rails are 2" different, and the Y brace attachment is different. If close, take David G's offer. Jim
I would but its about 6 hours from me. I can buy one with all linkage and good tires for 150 bucks. I'm good with a welder so I think I'll be able to fabricate something
the wide front under my H was from a M I took the big plate off and milled down the side to make it narrower. I have seen someone good with a torch use a straight edge and cut the sides as well. I also set up the part that bolts to the boaster in the mill and slotted the 2 holes to make it fit. My part was all welded up so wasn't to worried about wreeking a good one.
