dry sleeves
Steve43
New User
I put a set of sleeves in a 450 engine by warming the cylinder bores with trouble lights and chilling the sleeves in a freezer. They went in easy, maybe too easy. Three of them went in without any force required. I had cleaned the bores and the outside of the sleeves with paint thinner before installing them. After I had the pistons installed I turned the crankshaft and 2 sleeves came up with the pistons and I could knock the sleeves back down with a rubber mallet. They seem to be too loose so I am wondering if there is any good way to tighten the sleeves without installing oversize sleeves. The head would hold the sleeves down but I understand that the top flange on the sleeves might break and destroy the engine.
Sounds like you got the wrong sleeves. You could knurl them.
A method I used successfully on an 8N with a loose sleeve, modified a bit for your situation:
1) Measure the sleeve and the bore and calculate the additional diameter needed to get the desired interference fit.
2) Cover the sleeve with enough layers (stack ten layers and measure with your micrometer or calipers) of aluminum foil to add the desired diameter. Use a thin film of light oil to glue it in place. The foil should only go about halfway down the sleeve. Make certain that there are absolutely no wrinkles.
3) Plug the bottom of the sleeve with a wooden or plastic plug. Seal it with grease.
4) slide the sleeve into the bore to just short of the foil.
5) Fill the sleeve with liquid nitrogen. After a few minutes it should drop right in. Be sure the foil doesn"t get shoved up and wrinkled by the edge of the bore.
You could also just coat the sleeves with Loctite 660. Works great on bearings but I"d want to check temperatures before using it on a sleeve.
I have used KD block sealer a few times. It worked well. I have even used it to seal a small crack in a block from freezing.
I may try the Loctite or a block sealer. Not sure I want to try the liquid nitrogen and foil. Thanks for the ideas.
i have used thin loctite on the btm portion of the sleeve. dont forget the sleeve will expand into the cyl bore when hot, so i would not even worry about it.
i dont believe in using locktite in the upper portion of sleeve due to heat transfer.
I had the same problem with the sleaves on a Farmall H. I used the Loctite sleave retaing product (660?) and it has worked fine for several years. This was for one of my pulling tractors so it does work a little from time to time. The one comment that an experience auto machinisit made about using the retaing fluid was it would take a lot of heat to get the old sleaves out once you put them in.
I have a 460 diesel that one of the sleeves did that when I tore it down. didn't do anything but put it back, like the other guy says heat will expand them I wouldn't worry bout it.
I've had some engines where Locktite was used where we ended up having to bore the some of old sleeves out of the block.
sleeves when new, should be snug, but not "tight". Also, the metal ring around each bore is also part of the whole setup for the sleeves to stay in place. Personally, I would install them as is, and make sure you have the correct head gasket with the metal rings around the cylinder holes.
I know for a fact that some wet sleeves I have installed were not sloppy, but definately not tight. When I turned the engine over prior to installing the head, they moved a bit. Those engines are still running just fine, with no issues.
it's your tractor, and your decision. Personally, I would go with it. your mileage may vary.
