wheel weight embossed letters = ?
Al L. in Wisc.
Some scrape that a guy has contains three wheel weights. A single weight is embossed: W 161 F & H. What model(s) tractor would it apply to?
Begging your pardon on this board but, two matching weights are embossed: JD L40367. What green model would it be for? Thanks in advance for your input.
The F&H weight came from French & Hecht foundry. They built wheels and weights for various makes including MM JD &IH in the 30's I believe. The company passed through various hands and is today part of Titan's heritage.
Google is telling me that JD L40367 is evidently a cast wheel center for a JD 2750. The difference between a weight and a center should be fairly evident.
a 161 F&H weight is for round spoke wheels. its the 'starter' weight which is to be put on first. its a bit smaller diameter and thicker then the 162 weight that is to be added to the outside of a 161 weight
