Farmall F12 motor
James Williams
I am getting ready to put a F12 motor together,and I noticed a hair line crack starting from the head bolt stud hole and going both ways to the bore and to the oil return slot.Do you think that if I copper coat both sides of the head gasket will this crack will caues likage.This motor has wet sleves and no water pump
jimmy
I dont know,I could have done it when removing the head studs,I called a old tractor mechanic and took it out to the machine shop and both said they wouldnt worry about it,I think im going to put some JB weld on the stud threads and copper coat the head gasket
jimmy
