F656 power steering pump
Hello,
I was wondering the best way to remove a 656 steering hand pump. Mine has gone to leaking. Is it tricky putting seals in it or best to have it done at a shop?
Thanks YC
If it is leaking just under the steering wheel it is easy to do on the tractor. If it is leaking from the far end of the hand pump from the steering wheel. You need to remove from tractor and take apart. That is a bit of a different animal. You need to keep the parts in time or it could not react right.
