gas to lp conversion
1968 403
I am thinking about converting a c263 gas engine to LP. We have a Super M already on LP I am set up to fuel LP tractors here at home. The 263 engine has firecrater pistons. MY question is how much power and fuel economy will I loose converting the 263 to LP if I do not raise the compression of the engine. LP is half the price of gas here. I plan on using Impco parts. All replys appreciated
I would pull the head and have it gone thru before the conversion Plane the head to make it true. If it has valve rotators deactivate them. In a 560 that engine should make 65hp plus pto. Make sure to recurve the distributor for best performance.
This is memory so...
The lp head had stellite exhaust valves and seats. Reduce the time between valve lash adjustments if using a std head.
The distributor advance curve was a bit different as well, along with the timing setting.
High compression pistons
Exhaust and intake manifolds totally separated.
All that I can think of right now.....
do you have the tank and sheetmetal? I have if needed. I have one I bought to supply some other parts for my dads 560LP we have had since the . 70"s. love it. call 319-330-5848 to discuss.
Hi.
I did a lot of lp conversions over the years in pick ups. Mainly big block Chev. and Ford, and I always had good service with Impco kits. IH had those engines with factory lp so I would use their spec for the timing. If your engine has valve rotors I would take then out as propane is a dry fuel. As far as changing valves at the time of the converation, I would hold off until it starts to give trouble. I have run some big blocks chevs over 100,000 miles before I did the heads. If the head has been overhauled since unleaded gas was the norm it may already have better valves and seats which last pretty good. Also use the IH spec for the spark plugs, generally propane engines require a hotter plug. I go along with the 10% loss in power but it makes up for it with the savings in fuels costs.
Cheers
Russ
On the trucks I worked on they just put a spot of brazing on the rotators to keep them from turning when they did the conversions. When the heads were removed for service the rotators would be replaced with standard retainers. Starting about 1990 they no longer even did that much. It did not seem to make much difference in valve life.
If you have a later C263 you will already have Stelite valves and hardened seats in the head.
Thanks Owen The engine is a 1968 year model. I have been told it already has hardened seats and exhaust valves. Thanks everyone foe all the good advice. Keith
