I'm going plumb the Saginaw hitch this weekend, I was going to run a single line from the right side to a tee and then a line to each cylinder.
1. What size hose should I use w/belly pump?
2. what port on the cylinder do I plumb into (top or bottom)? (I think its the bottom but want to make sure)
3. Do I need to add a "breather" plug to the other port, I thought I read that in the archives somewhere?
thanks fellas, Anthony
