TractorLinks.com
Show Parts for Model:
Re: Farmall 460
D Slater
10-30-2013 20:01:56
Only problem is the T/A clutch won't release and that's going to cause hanging in gear and hard shifting which can lead to other problems. Correct setup releases the T/A clutch whenever the clutch pedal is pushed down. If the actual T/A unit ramp and roller unit was shot and never catches it wouldn't mater. Don't think that's the case with yours. Need to split at the engine rear, remove clutch shaft, other parts and get the top cover off the center housing. When you get enough removed the T/A release bearing and clutch comes out the top. Get a manual or other to do it. Step by step is more typing than I want now.
