TractorLinks.com
Show Parts for Model:
Re: Farmall 460
rustred
10-30-2013 19:34:18
why are u using it? if its for the hell of it then you dont need it. that T.A. was designed to be used when doing field work and under a heavy pull to be used for a short time.this was so you didnt have to stop and shift to a lower gear. once you got threw the tough spot you were to then use direct drive. another place it comes in handy is for baling hay when you run into heavy bunches in the windrow.. other than that the t.a. is just there and dont even think of it. you have 4 gears to select from and i have yet to find a reason to need a t.a. on any of these tractors. so if you dont want to spend a pile of money to fix it,m just dont use it and all will be fine.
