TractorLinks.com
Show Parts for Model:
Re: Difference in 06 and 56 tractors
IHnewbie
10-30-2013 14:23:46
I thought the 806 had a slightly smaller engine than the 1206? If not then that might be the route to go. Any other difference between the two besides turbo?
DeltaRed
10-30-2013 20:54:56
 Re: Difference in 06 and 56 tractors in reply to IHnewbie, 10-30-2013 14:23:46
806-1206 each had the D361.But the 1206 had the DT361.It was special built for the turbo.Cooling jets on the pistons,larger radiator,bigger fan to handle the extra heat.There may be more...The rear end/final drives are also heavier to handle the extra power.There is also the bigger Category 3 point hitch.So no,a 1206 is NOT an 806 with a factory turbo added.It is a completely different tractor.Similar, but different
willie in mn
10-31-2013 01:22:44
 Re: Difference in 06 and 56 tractors in reply to DeltaRed, 10-30-2013 20:54:56
I may be wrong on this, but IIRC reading about the 1206 they had to hold it off the market for some time. Gear train was beefed up, but had to wait for someone to make tires strong enough to withstand the torque.
WJ
willie in mn
11-01-2013 18:30:44
 Re: Difference in 06 and 56 tractors in reply to willie in mn, 10-31-2013 01:22:44
Can't give a direct quote, loaned the history book to my brother, he loaned it to his son, he loaned it to a buddy. Figure won't ever get it back.
Anyway, IIRC existing tires had plenty of traction, but the high torque would rip the sidewalls apart. Had to wait for someone to make a stronger tire.
Willie
Mark (ECIN)
10-31-2013 01:49:28
18.4 X 38 tires were put in production for the IH 1206.
24.5 X 32 tires were put in production for the Deere 5010
