TractorLinks.com
Show Parts for Model:
Re: 756 won't shut off
Dieseltech
10-30-2013 10:06:58
Lower lever must be pulled back and push start position plunger into spring loaded screw assembly for shutdown. When lever just touches the stop is correct engine start position for excess fuel, then full forward against front screw for run position. Adjust or replace cable as needed so operator can get all three locations.
2510Paul
10-30-2013 10:29:03
 Re: 756 won't shut off in reply to Dieseltech, 10-30-2013 10:06:58
Thanks, this sounds like it could be the solution. Paul
Dieseltech
10-30-2013 10:39:27
 Re: 756 won't shut off in reply to 2510Paul, 10-30-2013 10:29:03
You're welcome! Would also suggest keeping good filter service, and no water in fuel. That will keep the Bosch VA running long. Can still get parts to reseal them, but most hard parts are no longer around.
