Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Ignition Switch
Dave8N in Pa
10-28-2013 16:37:20
Quoting Removed, click Modern View to see Thank you Jim, That's a lot of help. The shut-off valve seems to need work and I think I'll take the carb apart as soon as I can get some gaskets. The manifold is broke and I don't know how long it's been run that way. I have been told that's a good way to warp exhaust valves so I'm going to check the compression first. But it didn't pop or puff when I ran it. I have a lot to do but I will follow up when I learn more. Thanks for the help!
Janicholson
10-28-2013 18:29:33
 Re: Ignition Switch in reply to Dave8N in Pa, 10-28-2013 16:37:20
Many engines run 1/2 of their lives with a broken exhaust manifold. Valve warpage from air hitting the valve is unlikely and would take extreme circumstances and over heating of the valve to do it. It is truly a myth. Replace the manifold with a good used if possible. New imported castings have been found difficult to work with as far as fit and hole location. A compression check is always good, but get it running with real gasoline first. Jim
