TractorLinks.com
Show Parts for Model:
Re: Ih 460
Janicholson
10-27-2013 18:19:01
I need to know (to assist you) what happens in the following circumstances:
Starting in 5th gear with the TA handle rearward, 3/4 throttle let out the clutch on a smooth level field road_________________________
Pulling a mold board plow in variable ground in 3rd with TA handle forward. The tractor slows, you pull the handle back quickly, ______________________
You pull up onto a slight grade leading into a barn door in 3rd, TA ahead, and push in the clutch. you stop and try to rake it out of gear.
Answers to these will help.
If when the lever is pulled rearward the tractor just plane stops, you are going to need a ramp and rollers (one way clutch) at least. It requires a double split to do the job. at the clutch to engine, and at the back of the clutch housing to transmission. Jim
