Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: C-169 Production
Absent Minded Farmer
10-18-2013 12:44:23
The number is 364265R1. The assembly number is 364266R93. It's neat to see that IH kept casting what would, in this day & age, be obsolete. I'll get some pictures on later. There's an odd plate on the left side of the block that I don't recognize. Might be a cover for a fuel pump hole, but the cam is on the other side. So....?
Mike
D Slater
10-18-2013 13:47:23
 Re: C-169 Production in reply to Absent Minded Farmer, 10-18-2013 12:44:23
Yes that's a replacement block number. Fuel pump could be mounted on the carburetor side and the block was drilled behind the plate for a push rod to camshaft. IH also used that block for a SH block replacement. But when used to replace a original SH block it required a different Piston and sleeve set.
10-18-2013 20:58:26
 Re: C-169 Production in reply to D Slater, 10-18-2013 13:47:23
[img]http://forums.yesterdaystractors.com/photos/mvphoto152.jpg[/img]
[img]http://forums.yesterdaystractors.com/photos/mvphoto153.jpg[/img]
[img]http://forums.yesterdaystractors.com/photos/mvphoto154.jpg[/img]
[img]http://forums.yesterdaystractors.com/photos/mvphoto155.jpg[/img]
[img]http://forums.yesterdaystractors.com/photos/mvphoto156.jpg[/img]
Well, if I did this right, there should be a bunch of pictures on your end of the string. If not, I'll try again tomorrow when I'm more awake.
Yes, it looks like there should be a fuel pump where the plate is. There's a support for a pushrod near the cam area.
I'd really didn't think I would run across such a find as this & I'd like to source as many NOS parts as I can for this project. The engine will eventually end up in my '42 H & power my mower & hay conditioner. It looks like a Firecrater set (@ Weber's) is in order for this job, but I just don't know if I want to keep it a 169 or bore it to a 175. I'd guess the 47 predicted HP for the 169 with the Firecrater set should be plenty enough power for the job. The H was a stock job & 26 HP was ok in average hay. The armpit high 1st crop we had this year was a bit much for it. The blasting medium in the engine may not have been much of a help, either.
Mike
