Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: cork oil pan gasket
10-18-2013 04:01:33
I am backing up the below statement. DO NOT use silicone on a cork gasket ever! It will "ooze" out and get into places it DOES NOT belong.Also,It will tend to break the gasket apart.(My transmission buddy knows this TOO WELL!)
My way of doing it: Make sure your oil pan rail is straight.if it is NOT,then either make it that way,or get another pan.(Be sure to get the bolt "dimpling" out of the pan bolt holes. A little work with a ball pien hammer, flat punch on a flat surface works good here.)
Take a SMALL amout/little dabs of something like 3M weather strip adhesive or Permatex "Hi Tack" and glue the gasket to the oil pan's rail,then oil the block surface where the gasket is sealing to the pan.Tighten the pan down evenly and DO NOT over tighten the pan bolts!!!!!
The ONLY time I ever use silicone on an oil pan is like on a BB Chev pan where the cork rail gaskets meet the rubber end gaskets. ONLY in the corners.;)
Was that "long winded" enough???? lol
John G. Hasler
10-18-2013 05:25:26
 Re: cork oil pan gasket in reply to mike1972chev, 10-18-2013 04:01:33
Silicone works fine a long you use it sparingly and let it dry. There should never be enough of any sealer to ooze out and if you don"t have time to let it dry completely don"t use it at all.
I agree that overtightening is the main source of trouble with sheet-metal pans (and with similar valve covers). It"s also a good idea to tighten the bolts in a pattern similar to that for a head.
