806 power beyond value for loader
Shahn
Could anyone tell me where to find a "power beyond valve" for an 806? I added a loader and am currently using one of the hydraulic remotes on the back with the lever tied down. It works but I would like to find a better option that doesn't tie up one of the remotes.
The power beyond end plate should be available from your CaseIH dealer.
With an 806, you may be lucky and have a valve stack with a separate end plate. That way you won't need to also buy another "middle" valve body to use with the power beyond end plate.
398316R1 is the number listed in the online parts book for the power beyond cover, but it's been superseded.
