TractorLinks.com
Show Parts for Model:
Re: 60's/70's Farmall IHC Help
DeltaRed
10-14-2013 08:45:24
The old farmalls have very good pats availability.The only one I can think of to be wary of is a 706 with D282.Not a bad tractor,but tend to be harder to start.IH used a lot of common parts in the rear end/transmission,and other places.Just about any IH of the 06/56 sereis would do you a good job.They are all good tractors.I run em!706(310 german diesel);826Hydro;1256.Have also owned:806;1026;856,others.
Jay Geneva
10-14-2013 09:40:16
 Re: 60's/70's Farmall IHC Help in reply to DeltaRed, 10-14-2013 08:45:24
Thanks for the feedback Its funny you mention the 706 I found a good deal on one but wasnt sure. Is cold weather the reason behind the hard starting issue as I'm in sunny Florida and we rarely see prolonged cold spells.
caseyc
10-14-2013 10:02:26
 Re: 60's/70's Farmall IHC Help in reply to Jay Geneva, 10-14-2013 09:40:16
The 706's with the D282 are known to start hard because they are a glow plug diesel. Folks tend to neglect them causing starting issues. As long as the system (ie; glow plugs, wiring, switch) are in good shape they start just fine. Even in your warm Florida climate you'll still need to hold the glow plug switch for about 20-30 seconds to start the tractor. They are a little light on power though compared to the later 706's which had the kraut D310. While the D310 is an excellent engine, it is very costly to overhaul while the D282 is much cheaper. Now if the 706 your looking at is gas, then this whole conversation is pointless... 8)
Casey in SD
mazemeister
10-14-2013 16:47:17
 Re: 60's/70's Farmall IHC Help in reply to caseyc, 10-14-2013 10:02:26
i'll second that. bought a 706 w/ 282 couple years ago for cheap and "needs work." got it running, all new glow plugs and switch. haven't done anything to engine, and it probably needs some attention. but it starts fine. needs 10 sec of glow plugs in the summer, maybe a minute in the winter. but it'll start.
Jay Geneva
10-14-2013 10:21:37
Great feedback Thanks I guess it falls back on keeping up good maintenance on your machine. What year did they switch from the 282 to the 310?
Hugh McKinney
10-14-2013 10:43:40
 Re: 60's/70's Farmall IHC Help in reply to Jay Geneva, 10-14-2013 10:21:37
Don't forget the 1456--the latest-introduced of the 56 series, and the most powerful! Plus a little beefier on the front end than even the mighty 1256. Just sayin'.
DeltaRed
10-14-2013 10:32:53
'67,last year of production.The 756 replaced the 706.Same basic tractor excapt for the shifters.
DeltaRed
10-14-2013 09:06:49
Jay, any one of the 706;756;806;856;1206;1256 tractors would serve well.
