Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 560 differential replacement
D Slater
10-14-2013 05:27:45
Remove transmission top, slide axles out enough to remove bull gears. Remove brakes, bull pinion gears and then differential carrier housings. If the 560 has all updates, tapered bearings are used to support the differential housing and a special tapered shim used on one side. Can't remember if the differential housing will wiggle out if the left side carrier housing is left in place. Depending on what's going on you may need it out anyway.
Nebraska Cowman
10-14-2013 06:04:49
 Re: 560 differential replacement in reply to D Slater, 10-14-2013 05:27:45
Yes, I'm thinking you only have to remove one side. But it's been a long time.
Copyright © 1997-2015 Yesterday's Tractor Co.
