TractorLinks.com
Show Parts for Model:
Re: H drive shaft
Janicholson
10-13-2013 19:57:25
If the hydraulic pump still works with the clutch out and the tractor in gear, the counter shaft and the constant mesh gear are still working. That means the PTO is still working.
If it will will not drive the rear wheels in 5th gear (as it would when starting out in that gear) then the issue is in the output shaft It has the differential pinion on it, or in the differential. (if it has a hand clutch aftermarket device that could be broken)
With it running and in 4th gear, (I assume not moving) step on the brakes. If that loads the engine, the issue is in the fina drives and or a broken axle. Let us know from these tests. Jim
