TractorLinks.com
Show Parts for Model:
Re: Farmall M falls flat on its face
FarmallKeith
10-13-2013 12:57:22
I will check the timing. This tractor starts right up.but does not idol. It is Always at high RPM's. I had the carb redone. Befor I bought it the top end was redone do to coolant in the oil.
wayne in mn
10-13-2013 14:49:55
 Re: Farmall M falls flat on its face in reply to FarmallKeith, 10-13-2013 12:57:22
Check the carb-to-governor connection; make sure the tab is in the notch of the carb throttle shaft.
David G
10-13-2013 13:08:24
An engine not idling can be caused by ignition problems. The ignition can be so screwed up it requires so much throttle to run that it never closes up and uses the idle jets.
Check the point gap first, then timing.
