TractorLinks.com
Show Parts for Model:
F-12 Pistons Rings
David McClellan
10-13-2013 11:10:08
I'm rebuilding an F-12 and the pistons are Conformatic GE-50YS. Can someone tell me the size of the rings and where to get them?
David McClellan
10-14-2013 16:28:29
 Re: F-12 Pistons Rings in reply to David McClellan, 10-13-2013 11:10:08
I had them measured for thickness, There are 2 compression rings that measure .093 or 2.4 mm and one oil ring that measures .18 or 4.59 mm. Does that help?
CharlieU
10-14-2013 17:14:38
 Re: F-12 Pistons Rings in reply to David McClellan, 10-14-2013 16:28:29
Dave, I changed your .180 measurement into 3/16 oil ring and the .093 to 3/32 compression rings. I need to know what is the bore of the engine. You could have a 3 inch or 3 1/8 (3.125) inch bore, you need to measure the inside Dia. of your sleeves. My e-mail is open. charlieu
John M
10-14-2013 08:22:16
Those brand of pistons were included, or at least use to be included, with a P"wer Seal engine kit. Maybe Goolge can help you with that.
CharlieU
10-14-2013 05:14:23
My brother in law is in the process of rebuilding a F-12 and he asked me to locate piston rings and a couple sleeves. After doing some pricing we figured out that it was cheaper to buy a piston sleeve kit that included new rings and piston pins. I was able to find 6 different ring sets for the F-12. Piston size and width of rings is information that is needed to order the correct set of rings.
Tom Fleming
10-14-2013 03:41:03
David, if those aren't the original pistons, you may have trouble finding rings for them. A couple of things you can do. One is to have the ring grooves turned to allow the rings you can find to fit. or, have custom rings made.
I do not recognize that make of piston, but who knows, might be very common.
gene bender
10-13-2013 17:34:51
You need to measure the bore and how thick are ALL of the are they the same thickness or are some thicker than others then you can get new ones
David McClellan
10-13-2013 17:50:45
 Re: F-12 Pistons Rings in reply to gene bender, 10-13-2013 17:34:51
The oil rings are 3/16, but the 1/8 compression rings from Y/T are too wide to fit in the grooves.
oldiron29
10-13-2013 16:08:45
I would check with YT parts on the left side of page. oldiron29
