Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall M falls flat on its face
gene bender
10-13-2013 10:48:57
remove a spark plug and look into the hole and you can see if they are domed or flat top.
FarmallKeith
10-13-2013 12:33:15
 Re: Farmall M falls flat on its face in reply to gene bender, 10-13-2013 10:48:57
The pistons are not flat heads the have a large dome. I did a compression test. From the front cylinder 100psi 125psi 105psi 110psi. Im also going the check out the govenor. Checking for broken springs debris build up make sure thing moves. Anymore ideas?
Janicholson
10-13-2013 20:13:12
 Re: Farmall M falls flat on its face in reply to FarmallKeith, 10-13-2013 12:33:15
Adjust the valves first then redo the compression test. Tight valves can do the deed. Jim
CNKS
10-13-2013 16:59:00
Cylinders are supposed to be within 10% of each other. It appears to me that one cylinder was fixed, the 125 one. The other 3 have normal wear. Number 1 is 25% less, 3 is 16% less. New flat tops should give about 120-125 psi. I don't know what psi your domed pistons are supposed to have, but the IH fire craters are about 135. I know zero about pulling, but your engine has some wear on it and what you may not notice in the field shows up in pulling.
