Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: c-123 engine into farmall super c???
El Toro
10-13-2013 04:49:46
That only affects the cid. Should give a little more power. The valves should be ground while the engine is torn down and carburetor should be ok. If you're going to work the tractor I would use at least 89 octane gas. The area where the sleeve seals are should be cleaned of any rust or crud so there's no coolant blockage. Have your local auto machine shop to grind the valves if any are too thin replace them. Hal
