Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: c-123 engine into farmall super c???
Janicholson
10-12-2013 17:09:42
If you use the torque tube starter position, you must use a tractor starter not the original engine side starter. They look alike but turn opposite. The SC starter spins CW looking from the brush end. The power unit style turns CCW from the brush end. Jim
Owen Aaland
10-13-2013 02:01:31
 Re: c-123 engine into farmall super c??? in reply to Janicholson, 10-12-2013 17:09:42
You have the directions correct as you list them but standard practice it to list the starter rotation when looking at it from the drive end. This is important when replacing such things as starter drives Lots of time the same style drive will be listed for CW and CCW rotation. If the starter installs from behind the flywheel toward the engine it is a CCW starter. If it installs along side the engine block to the back it is a CW starter.
