TractorLinks.com
Show Parts for Model:
Re: c-123 engine into farmall super c???
Boonville Kid
10-12-2013 14:32:04
If you make that revision to 133cid, do you have to make any changes to the carb. or to the valves?
El Toro
10-13-2013 04:49:46
 Re: c-123 engine into farmall super c??? in reply to Boonville Kid, 10-12-2013 14:32:04
That only affects the cid. Should give a little more power. The valves should be ground while the engine is torn down and carburetor should be ok. If you're going to work the tractor I would use at least 89 octane gas. The area where the sleeve seals are should be cleaned of any rust or crud so there's no coolant blockage. Have your local auto machine shop to grind the valves if any are too thin replace them. Hal
