Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: c-123 engine into farmall super c???
El Toro
10-12-2013 13:05:00
That's the Super C engine block and some late Super A's used that block. I would rebuild that block as you can install an over bore kit to give you 133cid. The piston diameter would be 3.250".
Hal
Boonville Kid
10-12-2013 14:32:04
 Re: c-123 engine into farmall super c??? in reply to El Toro, 10-12-2013 13:05:00
If you make that revision to 133cid, do you have to make any changes to the carb. or to the valves?
El Toro
10-13-2013 04:49:46
 Re: c-123 engine into farmall super c??? in reply to Boonville Kid, 10-12-2013 14:32:04
That only affects the cid. Should give a little more power. The valves should be ground while the engine is torn down and carburetor should be ok. If you're going to work the tractor I would use at least 89 octane gas. The area where the sleeve seals are should be cleaned of any rust or crud so there's no coolant blockage. Have your local auto machine shop to grind the valves if any are too thin replace them. Hal
