M brake cover
Anonymous-0
I cannot get the cover off the left side, I have all of the blots out and it is loosen the shaft housing, but will not come off. What am I doing wrong??
The pivot shaft is most likely rusted/stuck in the bushing that is pressed into the transmission housing. You could remove the lever & half-moon key to get the cover off and then use a pry tool behind the shaft ears.
