TractorLinks.com
Order Farmall Cub Parts Online
Re: Help with Cub PLEASE.
mkirsch
10-05-2013 16:39:13
If your Cub has the adjustment at the pedal, there isn't supposed to be an adjustment inside, AFAIK. Early Cubs adjusted the pedal free play internally, but only the real early ones. Obviously it is a royal pain in the hind-end to adjust up inside.
Newer Cubs have the clutch pedal free play adjustment at the base of the pedal.
Did you adjust the fingers on the pressure plate? They are supposed to be 1-1/4" from the back surface of the pressure plate frame to the highest point on the fingers where they rub on the throwout bearing.
You can shine a light up in the hand hole, and look through the upper implement mounting bolt hole in the bell housing to see what is happening. If the hole is plugged, just poke whatever it is out; it's usually just a chunk of cork.
Farmallb
10-05-2013 17:22:22
 Re: Help with Cub PLEASE. in reply to mkirsch, 10-05-2013 16:39:13
I don't know what/where an (upper implement mounting hole is, BUT, on the bell housing, one of the upper bolt holes was plugged, and both times I intended to get that unplugged, and forgot it both times till I had it bolted back and ran onto it running the bolts in.
Seems like, IF I shined a light as you suggest, id be somewhat aiming at that location. Plugged or not. What would that have to do with anything?
