roy prins
I was trying to level off the drawbar on my BN today-- there is 2 big bolts and a hole for some kind of stop -- my ? is what goes in the hole? is it some sort of double sized peg? thanks in advance for any insite!
The threads have been stripped in the hole that adjusts the height of the drawbar and replaced with some sort of a plug. Need to remove the drawbar and redo those threads with something like a helicoil. Or you could drill the hole and go to larger thread then drill the drawbar to take the new size. Not uncommon ive done it several times then you can have a level drawbar again.
