TractorLinks.com
Show Parts for Model:
Re: H no oil pressure update-thank you all
glennster
10-04-2013 14:09:22
zack, if the grooves are not too deep, you can lay a piece of emery paper on a thick sheet of glass and sand the cover smooth again. use a figure 8 pattern.
RustyFarmall
10-04-2013 14:51:27
 Re: H no oil pressure update-thank you all in reply to glennster, 10-04-2013 14:09:22
glennster, I tried that method on mine, but the grooves were simply too deep. I resoted to a bit more "crude" method (big flat file), and then finished up with the emory cloth trick. If there had been a milling machine handy (or machine shop), that would have been my first choice.
glennster
10-04-2013 14:54:49
 Re: H no oil pressure update-thank you all in reply to RustyFarmall, 10-04-2013 14:51:27
i did my farmall b oil pump with emery, it took a while but worked good. on the super m project i have now, i had a machine shop mill the cover, like yours, it was grooved too deep.
Spook
10-06-2013 17:46:58
 Re: H no oil pressure update-thank you all in reply to glennster, 10-04-2013 14:54:49
I put mine on a surface grinder. Better flatness than a mill.
