Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 1951 M Flywheel bolts sheared!
10-04-2013 13:19:51
couple guesses. first, bolts were not torqued tight enough, and over time loosened up, causing them to shear. or, someone put softer grade bolts in and they let loose. if the threads are still good, replace the bolts with the correct ones, and dowel pins, (may need to go to case i-h and get em) a little dab of lock-tite on each bolt will help.
10-04-2013 13:37:07
 Re: 1951 M Flywheel bolts sheared! in reply to glennster, 10-04-2013 13:19:51
Thanks, Glennster!
10-04-2013 17:52:53
 Re: 1951 M Flywheel bolts sheared! in reply to CrvnJ, 10-04-2013 13:37:07
Another option is too much torque on the bolts. Excess torque can and has caused many assembly failures. The bolts should be easy to remove. slot them with a dremel cutoff, and unscrew them. Jim
10-04-2013 13:58:00
i looked back at your other post and saw you have a chipped piston on cly number 2. i would pull that piston and check the wristpin, and also the rod bearing. having the tractor split at this point, you may want to think about doing a major on the engine. yt has the rebuild kits , and if you need a clutch, call mike at steel wheel ranch, he can set you up with the whole works very reasonable.
