TractorLinks.com
Show Parts for Model:
Re: Farmall M WITH A 283
Zachary Hoyt
10-04-2013 11:03:49
You have got a belly pump, it has one way hydraulic capability. You can hook a hose to any of the three ports and hook the other end to the raise end of a cylinder on an implement and see if it works. All three ports are together. It is possible to run a two way cylinder but it needs a lot of other non-stock parts.
Zach
sflem849
10-04-2013 11:51:00
 Re: Farmall M WITH A 283 in reply to Zachary Hoyt, 10-04-2013 11:03:49
Really...it has a gas V-8 in it and you are worried about non-stock hyd parts. :lol: I know what you mean.
Zachary Hoyt
10-04-2013 18:18:29
 Re: Farmall M WITH A 283 in reply to sflem849, 10-04-2013 11:51:00
I didn't mean that non-stock would be wrong, just that they were not likely already on the tractor.
Zach
lenray
10-04-2013 11:35:22
ZACHARY and Rusty--thank you. On the 283 there are two pulleys on the front of the engine. Could a fella hook up a hyd. pump that would run off a belt that would give a guy a live hyd. system for a two way cylinder??
DeltaRed
10-04-2013 11:37:23
 Re: Farmall M WITH A 283 in reply to lenray, 10-04-2013 11:35:22
Yes,you could hook a pump to the front...
RustyFarmall
10-04-2013 11:19:07
The lever for engaging the belly pump appears to be mostly missing. The pump won't do anything if you can't engage it.
