Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: want to change 1st gear to make tractor go slow
caterpillar guy
10-02-2013 19:10:00
Put smaller tires on it. That will slow it down. I don't know if it would be enough. It has 36's on now right. If you put 24's on it would slow you down probably about a 1/3-1/2 of normal speed.
10-03-2013 09:22:30
 Re: want to change 1st gear to make tractor go slow in reply to caterpillar guy, 10-02-2013 19:10:00
C=Pi x D or the circumference length is equal to Pi times the diameter. If you reduce the diameter from 3' to 2' the change in the wheel circumference is directly proportional or 2/3. So the speed would be reduced to 2/3's or 67% (from 3 mph to 2 mph as an example) and it would be a machine shop job to get it done. If this is what you need get another tractor with a low speed. These old Farmalls do not do everything and we did not try to make them back in the day.
