Behlen power steering
Anonymous-0
Did they make two different pumps a high preassure and a low pressure. Have a steering motor with the reservoir built in wondering if it is a low pressure setup.
This company made aftermarket parts for a bunch of different tractors. My P.S. uses the tractor hydraulic system and I think allot of the systems had their own separate pump.
SDE
On 450's they used strictly the tractor hydraulic system with a priority valve that "piggy-backs" onto the system--it is bolted in place with four bolts and has o-rings that route the fluid where it needs to go...but honestly it is not the best system...a person would do a lot better to adapt it to a modern priority valve, which I myself might do before long to take better advantage of the pump and actuator (hydraulic motor that is).
