Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: F20 coolant leak
36F30
10-01-2013 21:18:02
The holes for the manifold studs actually go clear through the head and need to be sealed with sealant during assembly. You will have to drain the coolant, remove the carb and manifold and then the stud. I use aviation form a gasket but any thread sealant should do. Coat the stud and put it back in. Might as well do them all while your at it. let it set up overnight and reinstall everything. The bolts holding the oil pan on also penetrate the block and will leak oil if not sealed and will mess up a nice paint job. Bottom line is the F series likes to mark their territory.
Copyright © 1997-2015 Yesterday's Tractor Co.
