Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: WOT trouble with A
10-01-2013 20:16:59
New is good. It may be that the fuel is just not getting to the carb, or through the needle and seat fast enough to supply the demand. it could also have new dirt in the carb main jet system. The fact that the idle mix screw no longer has an effect, is indicating dirt. I would put a thin wire through each passage and then follow with carb cleaner.
A failing coil can make the symptoms you describe. Not as likely as dirt, but possible. Jim
Mr Farmall
10-01-2013 20:30:26
 Re: WOT trouble with A in reply to Janicholson, 10-01-2013 20:16:59
The fuel seems to be flowing though the line okay. I cleaned out the carb a couple of weeks ago when I suspected a bad needle valve but it doesn't leak. Could a sticking needle valve cause such problems?
The coil is a pertronix epoxy filled coil. The contacts look a little rusty so I will try cleaning them.
Other thing is I am suspecting that the bumper surge spring could be worn out. If it is would it cause the problems I have been having?
10-01-2013 21:12:12
 Re: WOT trouble with A in reply to Mr Farmall, 10-01-2013 20:30:26
Bumper probably not.
Shut off the fuel at the tank. Remove the fuel bowl with carb still on the engine. Lift the float with finger pressure only. Turn on fuel. Put a can under the carb and lower the float to see fuel flow. it should come out strong and continue for 30 seconds or more, with no reduction in flow.
It should flow an equivalent 1/8" to 3/16" stream.
There is a strainer at the carb! Let us know. Jim
