Farmall H input shaft bearing
PretendFarmer
MY buddy believes his input shaft bearing is worn on his 1951 H. How do you go about replacing it? Can I get that bearing from Napa?
To replace it remove the belly pump and take out the four tapered
bolts in the plate in the input shaft. The input shaft will come out
of the clutch and then you can unbolt the input shaft bearing carrier
from the front of the transmission and remove it. I have good used
parts if you need them. I am sure the bearing can also be had new.
Zach
Our local NAPA is pretty good on bearings.Simply
take the number and they can match it up.Better
still,take the old one in as a sample.
