300 RC Power Steering.....Again
[b:c8054e0737]OK, I found a Behlen system with the torque generator, pulley, reservoir, hoses, pump and all the brackets (I think). Just want to make sure this will fit under the 300's hood.
Bruce[/b:c8054e0737]
Behlen is what IH used under the hood. Long as its the one with out a input shaft the steering wheel fits on, and it could be cut and used. Not sure what you mean by pulley? If its a crankshaft pulley like for a M to 450 size it won't work. Pumps I know of that mount under the hood of a 300 mount high on the left side of the engine with a reservoir and run off a longer generator belt. Sometimes the inside hood brace is cut.
